18 years agoCode not working for Quartus 2
Hi..I have made my VHDL code in Altera model Sim.Its working in Altera model sim but its showing error in Quartus 2..Can any boday help me whats errorr ??
1st file :- library IEEE; use IEEE.std_logic_1164.all; package mem is constant width : INTEGER := 4; constant mem_raw : INTEGER := 7; type word1 is Array(0 to mem_raw) of std_logic_vector(width-1 downto 0); type word2 is array(0 to (mem_raw-1)*2) of std_logic; --type Type_word is std_logic_vector(width-1 downto 0) of word; end mem; 2nd file :- library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; use work.mem.all; entity FA_calc is port( clk : std_logic; MTmux : in std_logic_vector(width-2 downto 0); MTdat : in std_logic_vector(width-2 downto 0); MTout : out word2; MTout_analyzer : out std_logic_vector(width-2 downto 0); load : in std_logic ); end FA_calc; architecture behav of FA_calc is signal sig_mem, sig_out : word1; signal counter : std_logic_vector(12 downto 0) := "0000000000000"; signal clkenable : std_logic; begin clkdiv : process(clk) begin if clk = '1' and clk'event and clkenable = '1' then counter <= counter + 1; end if; end process; ----decoder and data transfer code---- trans : process(MTmux, counter) begin clkenable <= '1'; if counter = "1101001000000" then case MTmux is when "000" => sig_mem(0)(width-1 downto 1) <= MTdat; when "001" => sig_mem(1)(width-1 downto 1) <= MTdat; when "010" => sig_mem(2)(width-1 downto 1) <= MTdat; when "011" => sig_mem(3)(width-1 downto 1) <= MTdat; when "100" => sig_mem(4)(width-1 downto 1) <= MTdat; when "101" => sig_mem(5)(width-1 downto 1) <= MTdat; when "110" => sig_mem(6)(width-1 downto 1) <= MTdat; when others => NULL; end case; counter <= "0000000000000"; clkenable <= '0'; end if; end process trans; ---load data to output--- ld : process(load) begin if load'event then ---- depend on the switch sig_mem(0)(0) <= '0'; sig_mem(1)(0) <= load; for i in 0 to 5 loop case sig_mem(i+1) is when "0000" => sig_out(i+1)(width-2 downto 0) <= "000"; when "0100" => sig_out(i+1)(width-2 downto 0) <= "000"; when "1100" => sig_out(i+1)(width-2 downto 0) <= "001"; when "1110" => sig_out(i+1)(width-2 downto 0) <= "001"; when "0110" => sig_out(i+1)(width-2 downto 0) <= "011"; when "0010" => sig_out(i+1)(width-2 downto 0) <= "011"; when "1010" => sig_out(i+1)(width-2 downto 0) <= "010"; when "1011" => sig_out(i+1)(width-2 downto 0) <= "010"; when "0011" => sig_out(i+1)(width-2 downto 0) <= "110"; when "0111" => sig_out(i+1)(width-2 downto 0) <= "110"; when "1111" => sig_out(i+1)(width-2 downto 0) <= "111"; when "1101" => sig_out(i+1)(width-2 downto 0) <= "111"; when "0101" => sig_out(i+1)(width-2 downto 0) <= "101"; when "0001" => sig_out(i+1)(width-2 downto 0) <= "101"; when "1001" => sig_out(i+1)(width-2 downto 0) <= "100"; when "1000" => sig_out(i+1)(width-2 downto 0) <= "100"; when others => NULL; end case; sig_mem(i+2)(0) <= sig_out(i+1)(width-2); end loop; end if; end process ld; ---data out--- MTout_analyzer <= sig_mem(0)(width-1 downto 1); MTout(0) <= sig_out(1)(width-3); MTout(1) <= sig_out(1)(width-2); MTout(2) <= sig_out(2)(width-3); MTout(3) <= sig_out(2)(width-2); MTout(4) <= sig_out(3)(width-3); MTout(5) <= sig_out(3)(width-2); MTout(6) <= sig_out(4)(width-3); MTout(7) <= sig_out(4)(width-2); MTout(8) <= sig_out(5)(width-3); MTout(9) <= sig_out(5)(width-2); MTout(10) <= sig_out(6)(width-3); MTout(11) <= sig_out(6)(width-2); MTout(12) <= sig_out(6)(width-1); end behav; Thanks a lot.
