18 years agoThanks for your help..
i have made small chage in my code but here i could not able to assign value..ie.. code :- library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; use work.mem.all; entity FA_calc is port( clk : std_logic; MTmux : in std_logic_vector(width-2 downto 0); MTdat : in std_logic_vector(width-2 downto 0); MTout : out word2; MTout_analyzer : out std_logic_vector(width-2 downto 0); load : in std_logic ); end FA_calc; architecture behav of FA_calc is signal sig_mem : word1; signal sig_out : word3; --signal cnt1: integer range 0 to 7 ; --signal counter : std_logic_vector(12 downto 0) := "0000000000000"; --variable cnt : integer range 0 to 6720; signal clkenable,num : std_logic; signal wire1: std_logic; begin clkdiv : process(clk,MTmux) variable cnt: integer range 0 to 2 ; variable cnt1: integer range 0 to 7 ; begin clkenable <= '1'; if clk = '1' and clk'event then --counter <= counter + 1; cnt := cnt + 1; if (cnt = 2) then cnt1 := cnt1 +1; case MTmux is when "000" => sig_mem(0)(width-1 downto 1) <= MTdat; when "001" => sig_mem(1)(width-1 downto 1) <= MTdat; when "010" => sig_mem(2)(width-1 downto 1) <= MTdat; when "011" => sig_mem(3)(width-1 downto 1) <= MTdat; when "100" => sig_mem(4)(width-1 downto 1) <= MTdat; when "101" => sig_mem(5)(width-1 downto 1) <= MTdat; when "110" => sig_mem(6)(width-1 downto 1) <= MTdat; when others => NULL; end case; cnt := 0; if (cnt1 =4) then sig_mem(1)(0) <= load; clkenable <= '0'; end if; end if; end if; end process; ld : process(load,clkenable,sig_mem) begin if clkenable ='0' then -- sig_mem(1)(0) <= '0'; sig_mem(1)(0) <= load; for i in 0 to 5 loop case sig_mem(i+1) is when "0000" => sig_out(i+1)(width-2 downto 0) <= "000"; when "0100" => sig_out(i+1)(width-2 downto 0) <= "000"; when "1100" => sig_out(i+1)(width-2 downto 0) <= "001"; when "1110" => sig_out(i+1)(width-2 downto 0) <= "001"; wire1 <= '0'; when "0110" => sig_out(i+1)(width-2 downto 0) <= "011"; when "0010" => sig_out(i+1)(width-2 downto 0) <= "011"; when "1010" => sig_out(i+1)(width-2 downto 0) <= "010"; when "1011" => sig_out(i+1)(width-2 downto 0) <= "010"; when "0011" => sig_out(i+1)(width-2 downto 0) <= "110"; when "0111" => sig_out(i+1)(width-2 downto 0) <= "110"; when "1111" => sig_out(i+1)(width-2 downto 0) <= "111"; when "1101" => sig_out(i+1)(width-2 downto 0) <= "111"; when "0101" => sig_out(i+1)(width-2 downto 0) <= "101"; when "0001" => sig_out(i+1)(width-2 downto 0) <= "101"; when "1001" => sig_out(i+1)(width-2 downto 0) <= "100"; when "1000" => sig_out(i+1)(width-2 downto 0) <= "100"; when others => NULL; end case; sig_mem(i+2)(0) <= sig_out(i+1)(width-2) end loop; end if; end process ld; -- ld1 : process(sig_mem) -- begin -- sig_mem(2)(0) <= sig_out(2); -- end process ld1; end behav; sig_mem(i+2)(0) <= sig_out(i+1)(width-2) :- here out put of first loop is the input of the Sig_mem but i could not able to assign my value..Any idea how to assign last output of2nd bit is the input of the next sig_mem o bit ?? Thanks a lot.
