12 years ago
close loop at Test Bench
Hi ,
i want to close loop back at the Test bench between the transmitted data from transmitter to the receiver .
both transmitter and receiver implemented at VHDL and they are known to the top .
a,b - output ports
c,d - input ports
i instantiate the output from transmitter entity - serial_out is the output of the generator entity inside transmitter entity :
serial_out => a ;
i instantiate the output from top entity :
a => b ;
i instantiate the output b to input of the top from test bench to close the loop :
b => c ;
i instantiate the input from top entity :
c => d ;
i instantiate the input from receiver entity - serial_in is the input of the receiver sub entity inside receiver entity:
d=> ser_in ;
after simulation at modelsim there are error massage :
" Unknown formal identifier " for a,b,c,d .
what did i do wrong ?
do i need to instantiate the program deferentially ?
file attached .
    --- Quote Start ---
    At the Rx file ser_in as input port ,
    At the Rx file i declare data_in as signal and connect : Data_in=> Data_in_D .
    There are 11 errors at Rx file after compiling .
    one of the errors is :
    1. ** Error: D:/Final Project/Technical/Top/hdl/Rx.vhd(34): (vcom-1136) Unknown identifier "Data_in_D".
    Data_in_D is the input port to MetaFix - declared at Rx file . i tried to declare it as a signal at Rx file but still it has the same error .
    --- Quote End ---
    No it is not declared in rx_vhd. It is port to submodule(Metfix). Thus it is unknown at rx_vhd.
    Just make a search for every errored signal and see if it is declared.
    Hi kaz ,
    i'm a little confused ... i did defined data_in , data_in_D and all the rest of the signals as signals at Rx.vhd and still there are many errors .
    lines 17-26 at Rx.vhd :
    signal data_in : std_logic;
    signal Data_in_D : std_logic;
    signal PN_in : std_logic; -- PN_in is the output of the block PN_Transmitter
    signal cmp_out : std_logic; -- cmp_out is the output of the block comparator
    signal reg_in :std_logic;
    signal reg_in_signal1: std_logic;
    signal cmp_in_signal1: std_logic_vector(7 downto 0);
    signal cmp_in_signal2: std_logic_vector(7 downto 0);
    signal x : std_logic; -- x is the comparator output
    signal PN_out2 : std_logic; -- PN_out2 is the second PRBS output
    what do i need to do more ?
    The error relates to the metafix entity. It has no port called data_in, its called data_in_d.
    And I suspect the rest of the problems are similar (you named the ports incorrectly, not the signals.
    On another note - some of these connections do nothing. For example, in RX, the data_in_d signal is connected to nothing.
    i changes the instanstiation order and now it compile without errors .
    Thanks a lot guys , you're awesome !
