Hi kaz ,
i'm a little confused ... i did defined data_in , data_in_D and all the rest of the signals as signals at Rx.vhd and still there are many errors .
lines 17-26 at Rx.vhd :
signal data_in : std_logic;
signal Data_in_D : std_logic;
signal PN_in : std_logic; -- PN_in is the output of the block PN_Transmitter
signal cmp_out : std_logic; -- cmp_out is the output of the block comparator
signal reg_in :std_logic;
signal reg_in_signal1: std_logic;
signal cmp_in_signal1: std_logic_vector(7 downto 0);
signal cmp_in_signal2: std_logic_vector(7 downto 0);
signal x : std_logic; -- x is the comparator output
signal PN_out2 : std_logic; -- PN_out2 is the second PRBS output
what do i need to do more ?
