14 years agoExplicitly assigned the clock as "Global" seems to make no difference. Running with partitions turned off doesn't help either.
Early on, I get this message: Warning: Can't implement Global Signal option for node "lanai_clk_reset:clk_reset|ungatedClkCore" that drives nodes that cannot change routing due to incremental compilation -- other nodes are not affected But, in fact, it does assign the net to a global clock. Later, it says: Info: Promoted node lanai_clk_reset:clk_reset|ungatedClkCore Info: Promoted destinations to use location or clock signal Global Clock CLKCTRL_G10 Info: Following destination nodes may be non-global or may not use global or regional clocks Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[24] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[23] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[20] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[18] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_input_ctrl_sg[7] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[22] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[21] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[19] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[17] Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[16] Info: Non-global destination nodes limited to 10 nodes
