Explicitly assigned the clock as "Global" seems to make no difference. Running with partitions turned off doesn't help either.
Early on, I get this message:
Warning: Can't implement Global Signal option for node "lanai_clk_reset:clk_reset|ungatedClkCore" that drives nodes that cannot change routing due to incremental compilation -- other nodes are not affected
But, in fact, it does assign the net to a global clock.
Later, it says:
Info: Promoted node lanai_clk_reset:clk_reset|ungatedClkCore
Info: Promoted destinations to use location or clock signal Global Clock CLKCTRL_G10
Info: Following destination nodes may be non-global or may not use global or regional clocks
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[24]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[23]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[20]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[18]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_input_ctrl_sg[7]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[22]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[21]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[19]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[17]
Info: Destination node lanai_top:lanai_top|sysc_top:sysc_top|sysc_reg_control:sysc_reg_control|video_output_ctrl_sg[16]
Info: Non-global destination nodes limited to 10 nodes
