Clock missing from Timing Analyzer - Report Setup Summary
What are all those false paths you've created? Are you preventing analysis on the paths that are clocked by HDMI_TX_CLK?
Run Report Timing and specify you're looking for paths clocked by this clock.
- Mikexx2 years ago
Those false paths were the ones setup in Timing Analyzer by default and placed in the sdc file. All I did was add HDMI_TX_CLK into the "Create Clock" group in the sdc file.
I have no idea why it would do that and I don't recognise the names.
- sstrell2 years ago
So you should run detailed timing reports with Report Timing, setting the launch or latch clock as HDMI_TX_CLK to find paths clocked by this clock domain.
- Mikexx2 years ago
If I go to Custom Reports -> Report Timing I an enter HDMI_TX_CLK into the from and to clock. These exist in the pull-down option.
I placed * in the targets entry, leave it blank, or add all registers in the design. I get "Nothing to report" for all options.
Not sure if it makes a difference bu I'm using Quartus Prime Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition
