Mikexx
2 years agoClock missing from Timing Analyzer - Report Setup Summary
I have a clock mux along the lines in "ug-qps-03-design-recommendations.pdf" I have set the output clock to be a Global Clock in the Assignment Editor and I give it's minimum period in the sdc file....
Mikexx
2 years agoMany thanks.
The "Report Clocks" does list this clock as I would expect.
HDMI_TX_CLK, or some variant of it, is clocking a lot of logic other pins are dependent on this and are behaving as expected. The same signal is used throughout the design so how can I check that setup and hold times aren't violated?
