Mikexx
2 years agoClock missing from Timing Analyzer - Report Setup Summary
I have a clock mux along the lines in "ug-qps-03-design-recommendations.pdf" I have set the output clock to be a Global Clock in the Assignment Editor and I give it's minimum period in the sdc file....
sstrell
2 years agoSo HDMI_TX_CLK is an output clock you are creating and you say it is being used to clock internal logic as well?
Run Report Clocks, not a setup summary, to verify clocks in your design. If it's not showing up in setup summary, that means it's not clocking anything internally.
