Clock missing from Timing Analyzer - Report Setup Summary
Many thanks for your reply.
Second attempt at posting!
I haven't made any changes to the Assignment Editor, but deleted/renamed the old sdc file and created a new one from Timing Analyzer.
These are now the active lines in the sdc file:
create_clock -name {altera_reserved_tck} -period 33.333 -waveform { 0.000 16.666 } [get_ports {altera_reserved_tck}]
create_clock -name {HDMI_TX_CLK} -period 6.750 -waveform { 0.000 3.375 } [get_ports {HDMI_TX_CLK}]
set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -setup 0.280
set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -hold 0.270
set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -setup 0.280
set_clock_uncertainty -rise_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -hold 0.270
set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -setup 0.280
set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -rise_to [get_clocks {altera_reserved_tck}] -hold 0.270
set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -setup 0.280
set_clock_uncertainty -fall_from [get_clocks {altera_reserved_tck}] -fall_to [get_clocks {altera_reserved_tck}] -hold 0.270
set_clock_groups -asynchronous -group [get_clocks {altera_reserved_tck}]
set_false_path -from [get_keepers {*rdptr_g*}] -to [get_keepers {*ws_dgrp|dffpipe_ed9:dffpipe15|dffe16a*}]
set_false_path -from [get_keepers {*delayed_wrptr_g*}] -to [get_keepers {*rs_dgwp|dffpipe_dd9:dffpipe12|dffe13a*}]
set_false_path -from [get_keepers {*rdptr_g*}] -to [get_keepers {*ws_dgrp|dffpipe_hd9:dffpipe19|dffe20a*}]
set_false_path -from [get_keepers {*delayed_wrptr_g*}] -to [get_keepers {*rs_dgwp|dffpipe_gd9:dffpipe13|dffe14a*}]
set_false_path -from [get_keepers {*rdptr_g*}] -to [get_keepers {*ws_dgrp|dffpipe_rd9:dffpipe8|dffe9a*}]
set_false_path -from [get_keepers {*delayed_wrptr_g*}] -to [get_keepers {*rs_dgwp|dffpipe_qd9:dffpipe5|dffe6a*}]
set_false_path -from [get_keepers {*rdptr_g*}] -to [get_keepers {*ws_dgrp|dffpipe_pd9:dffpipe8|dffe9a*}]
set_false_path -from [get_keepers {*delayed_wrptr_g*}] -to [get_keepers {*rs_dgwp|dffpipe_od9:dffpipe5|dffe6a*}]
After compiling the design which fitted fine and very quickly, I reopened Timing Analyzer, "Read the SDC File", double clicked "Report Setup Summary" and got a single line:
altera_reserved_tck 7.788 0.000
There was no line in the table indicating HDMI_TX_CLK
I am using SignalTap where the clock is also the missing clock HDMI_TX_CLK. SignalTap works as expected. The fitter report says it found "2 clocks" consistent with the SDC file. There are some expected warnings from not specifying the periods of input clocks that are specified in PLLs.
One thing that bothers me is this line and is mentioned 5 times in the processing messages:
Info (13166): Register RX_Video:RX_Video_1|RX_Toggle is being clocked by CLK_50_Bank7A
CLK_50_Bank7A is the input clock feeding the PLLs, where a couple are used to create 4 clocks that are muxed onto HDMI_TX_CLK.
In the design Register RX_Video:RX_Video_1|RX_Toggle is being clocked by a clock that selected from1 of 4 clocked the same way HDMI_TX_CLK is created.
