anonimcs
Contributor
2 years agoClock groups ignored by Timing analyzer
Hi all, I have a design with multiple clock domains. I want to ignore the timing checks for the paths where CDC happens. For this purpose, I have set clock groups in my sdc file, code can be found b...
- 2 years ago
The issue was that the .sdc file was read before all the other .ip files are read in the .qsf file. When I moved the line to read the .sdc file after reading the .ip files, the issue is gone, and I can see false paths set in the report for clock transfers. This issue was also mentioned in this article here. In case the link becomes broken in the future, I attach a screenshot of the link content below.
TingJiangT_Intel
Contributor
2 years agoCould you please provide your project (.qar) for investigation. You can remove all RTL files for confidentiality.
Thanks a lot.
anonimcs
Contributor
2 years agoCould you specify the archive settings that you want ? I don't want to provide 'too less' files to you, but checking all boxes here generates gigabytes of data...
