anonimcs
Contributor
2 years agoClock groups ignored by Timing analyzer
Hi all, I have a design with multiple clock domains. I want to ignore the timing checks for the paths where CDC happens. For this purpose, I have set clock groups in my sdc file, code can be found b...
- 2 years ago
The issue was that the .sdc file was read before all the other .ip files are read in the .qsf file. When I moved the line to read the .sdc file after reading the .ip files, the issue is gone, and I can see false paths set in the report for clock transfers. This issue was also mentioned in this article here. In case the link becomes broken in the future, I attach a screenshot of the link content below.
sstrell
2 years agoCan you show your create_clock constraints? Something is not making sense here. What is your target device and Quartus version?
anonimcs
Contributor
2 years agoThe target device is Arria 10 and I'm using the Quartus version 21.3 Pro. I attached my .sdc file here so that you can have a better sight on my constraints.
