12 years ago
clock division in verilog
I'd like some help to understand why this code didn't work.
module emissao2(
clk,
enable_in,
over_temp_in,
MSB_in,
LSB_in,
enable_led,
over_temp_led,
MSB_led,
LSB_led,
enable_out,
over_temp_out,
MSB_out,
LSB_out,
ctrl_p_1,
ctrl_n_1,
ctrl_p_2,
ctrl_n_2,
ctrl_p_3,
ctrl_n_3,
ctrl_p_4,
ctrl_n_4);
//---Input Ports---
input clk;
input enable_in;
input over_temp_in;
input MSB_in;
input LSB_in;
//---Output Ports---
output enable_led;
output over_temp_led;
output MSB_led;
output LSB_led;
output enable_out;
output over_temp_out;
output MSB_out;
output LSB_out;
output ctrl_p_1;
output ctrl_n_1;
output ctrl_p_2;
output ctrl_n_2;
output ctrl_p_3;
output ctrl_n_3;
output ctrl_p_4;
output ctrl_n_4;
//---Input Ports Data Type---
wire clk;
wire enable_in;
wire over_temp_in;
wire MSB_in;
wire LSB_in;
//---Output Ports Data Type---
reg enable_led;
reg over_temp_led;
reg MSB_led;
reg LSB_led;
reg enable_out;
reg over_temp_out;
reg MSB_out;
reg LSB_out;
reg ctrl_p_1;
reg ctrl_n_1;
reg ctrl_p_2;
reg ctrl_n_2;
reg ctrl_p_3;
reg ctrl_n_3;
reg ctrl_p_4;
reg ctrl_n_4;
reg [3:0]count;
initial begin
count = 4'd0;
ctrl_p_1 = 1'b0;
end
always @(posedge clk)
begin
if(count==4'd10)
begin
count<=3'd0;
ctrl_p_1 <= ~ctrl_p_1;
end
else
begin
count<=count+1;
end
end
endmodule
It compile but does not work. I made the assignments correctly, and i will use all this ports, this is just a inicial code just to see if works.
I'm using Quartus II 13.0, to program Altera DE2 (EP2C35F672C)
    Initial blocks are not synthesizable. Change it to a reset condition of your always @(posedge clock)
    Pete
    You missed to say what "didn't work" in your code. In the present code, ctrl_p_1 will be toggled after each 10 clock cycles.
    --- Quote Start ---
    --- Quote End ---
    They are synthesized as initialization during power on reset. Initializing to 0 is redundant, because this is the default register state without additional initializations. A reset condition can be repeated at will, in contrast to POR which is only performed once.
