Clock constraints for divided clocks
- 2 years ago
You may checkout the forum post here:
It seems for these very low frequencies you just lie. R
Reference:Best Regards,
Richard Tan
I tried your suggestion to set the source for each of those as the input pin to cnt2 and cnt3 instead of the output pin of the previous block. But I got the same result.
#create_generated_clock -name PLS1r57ms -source [get_pins {SLOWCLK_1|cnt1|count[0]|clk}] -divide_by 15700 [get_pins {SLOWCLK_1|cnt1|count[13]|q}]
create_generated_clock -name PLS1r57ms -source [get_pins {PLL_inst|altpll_component|auto_generated|pll1|clk[0]}] -divide_by 15700 -duty_cycle 0.478 [get_pins {SLOWCLK_1|cnt1|count[13]|q}]
#create_generated_clock -name PLS7r85ms -source [get_pins {SLOWCLK_1|cnt1|count[13]|q}] -divide_by 5 -duty_cycle 0.2 [get_pins {SLOWCLK_1|cnt2|count[2]|q}]
create_generated_clock -name PLS7r85ms -source [get_pins {SLOWCLK_1|cnt2|count[0]|clk}] -divide_by 5 -duty_cycle 0.2 [get_pins {SLOWCLK_1|cnt2|count[2]|q}]
#create_generated_clock -name PLS94r2ms -source [get_pins {SLOWCLK_1|cnt2|count[2]|q}] -divide_by 12 -duty_cycle 0.33 [get_pins {SLOWCLK_1|cnt3|count[3]|q}]
create_generated_clock -name PLS94r2ms -source [get_pins {SLOWCLK_1|cnt3|count[0]|clk}] -divide_by 12 -duty_cycle 0.33 [get_pins {SLOWCLK_1|cnt3|count[3]|q}]
Looking again, duty_cycle should be a percentage. Try 20 and 33 instead of .2 and .33.
- HKana172 years ago
Dear sstrell,
Thank you for your reply.
I got that the duty cycle number was of percent. Thank you. Today I didn't write duty cycle numbers.
I found 2 constraints for PLS7r85ms and PLS94r2ms clocks actually ignored. So far I have seen only the report tree of Timing Analyzer. Today I found messages in the console of Timing Analyzer.
But I can't understand what it means. I attache the messages below.
Why the rise and fall edges of PLS7r85ms clock 'identical'?The period, rise edge, or fall edge of clock: PLS7r85ms was found to be outside of the range of acceptable time values. The minimum acceptable time value is -2147483.647 and the maximum acceptable time value is 2147483.647. This clock will be ignored.
The calculated rise and fall waveform edges for clock: PLS7r85ms were found to be identical (rise: -2147483.647, fall: -2147483.647). This clock will be ignored.
Ignoring clock spec: PLS94r2ms Reason: Clock derived from ignored clock: PLS7r85ms. Clock assignment is being ignored.
Node: SLOWCLK:SLOWCLK_1|bin_counter5:cnt2|count[2] was determined to be a clock but was found without an associated clock assignment.
Register OC_DETECT:OC4|TIMER64count:TIMER64count_1|COUNT_UP is being clocked by SLOWCLK:SLOWCLK_1|bin_counter5:cnt2|count[2]
Node: SLOWCLK:SLOWCLK_1|bin_counter12:cnt3|count[3] was determined to be a clock but was found without an associated clock assignment.
Register TIMER1Kcount:TIMER1Kcount_17|COUNT_UP is being clocked by SLOWCLK:SLOWCLK_1|bin_counter12:cnt3|count[3]Regards,
