CLK-30028 - Invalid Generated Clock
I'm not sure why the Design Assistant is calling this out, but since you're using a 3rd-party tool, you should issue a write_sdc command (or choose the option in the Timing Analyzer) to write out a full .sdc file for use by the other tool that will include the correct create_generated_clock constraints.
Other than that, if your timing analysis is accurate and you are closing timing, I'd ignore the DA.
- OrF2 years ago
the 3rd-party tool is for the Synthesis Part not for the P&R and timing closure . therefore I dont see the point to provide the sdc to the 3rd-party tool , even though I did generated the sdc, and looking at it I didn't find any additional constraints .
this issues DOES effect the timing calculation since it doesn't take into account the the timing delay from the input of the pll to the output of the pll.
