Chip planner
Hi
I'd like to understand what size of LL I should select. Is there an option in the "Chip Planner" tool to determine whether my selection (logic lock) is smaller or larger?
My design includes a lot of logic elements, I don't want to wait 10 hours to know if there is enough space in the LL area.
Again, you can use the compilation without LL regions as a guide. You could also create your LL region as unlocked/floating, allowing the Fitter to select a size and location for the region. You can then customize the resulting Fitter-created region based on this result (which you would want to do because the Fitter will only make it big enough to contain the assigned logic).
- ymiler2 years ago
Contributor
OK
Thank you.
what about my previous question:
I get information about the region lock from the chip planner, but it seems that something wrong with the data.
can you explain the info about the M20K below:
and what about another screenshot:
How can I have -3 ALM ???
same question about the percentage:
Quartus version 22.3
