13 years ago
Chip Planner issues about show delays
I have a question about the Chip Planner.
I am using QuartusII 11.1 + sp1. I found that the chip planner can't show the delays as other old verstion.
I have turned on the "show delay" button, but no effect.
    How to let the QII to show the routing path delay? Or is there any bug for this version about this function?
    Could you find the solution of this problem?
    I'm using quartus 10.1 and want to check the delays as well
    --- Quote Start ---
    --- Quote End ---
    Enable the Timequest and check respond path delay in Timequest.
    Humm ok, but this is not really as graphical as we could see in the previous version of quartus, right?
    What I found is just a list containing the delays, but still I couldn't see the delay when I clicked in the logical elements in pin planner. Or you found a way to show it there?
    regards.
    If you enable TimeQuest and locate the path what you want to check into chip-planner again, then you can see the delay. Also, you can check the delay in TQ directly.
