Changed PERST# to 1.8V and Quartus crashed.
If you tell me I can't make PERST# 1.8V compatible, I'm going to have to rework my board.
Here is the dump from the code:
Problem Details
Error:
Internal Error: Sub-system: FIOMGR, File: /quartus/fitter/fiomgr/fiomgr_io_manager_impl.cpp, Line: 7696
result
Stack Trace:
0xecc54: FIOMGR_IO_MANAGER_IMPL::set_voltage_of_the_bank_if_needed(FIOMGR_IO_BANK*, CDB_ATOM_NODE*) + 0x354 (fitter_fiomgr)
0xed525: FIOMGR_IO_MANAGER_IMPL::body_legality_check(FITCC_MSGR*) + 0x575 (fitter_fiomgr)
0x99db2: FIOMGR_IO_MANAGER::legality_check(FITCC_MSGR*) + 0xf2 (fitter_fiomgr)
0x57110: FSV_EXPERT::create_and_initialize_utilities() const + 0x2c0 (fitter_fsv)
0x58ca9: FSV_EXPERT::fitter_preparation_pre_fpp() + 0x649 (fitter_fsv)
0x598a6: FSV_EXPERT::fitter_preparation() + 0x26 (fitter_fsv)
0x4b5f2: FSV_EXPERT_BASE::fitter_preparation() const + 0x312 (fitter_fsv)
0x4d7f0: FSV_EXPERT_BASE::invoke_fitter() const + 0xc80 (fitter_fsv)
0x4812d: fsv_execute + 0x48d (fitter_fsv)
0x22762: fmain_start(CMP_FACADE*) + 0x4a2 (fitter_fmain)
0x23174: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x1c4 (comp_qfit_legacy_flow)
0x16fa6: QFIT_FRAMEWORK::execute() + 0x1b6 (comp_qfit_legacy_flow)
0x3bb45: qfit_legacy_flow_run_legacy_fitter_flow + 0x515 (comp_qfit_legacy_flow)
0x48109: TclInvokeStringCommand + 0x79 (tcl8.6)
0x4c977: TclNRRunCallbacks + 0x47 (tcl8.6)
0x4e1ca: TclEvalEx + 0x96a (tcl8.6)
0xf68c6: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
0xf69ce: Tcl_EvalFile + 0x2e (tcl8.6)
0x11a90: qexe_evaluate_tcl_script(std::string const&) + 0x3c9 (comp_qexe)
0x1702d: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x824 (comp_qexe)
0x181d1: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x640 (comp_qexe)
0x38da5: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xe68 (comp_qcu)
0x1adf5: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x486 (comp_qexe)
0x36f0: qfit2_main(int, char const**) + 0xd0 (quartus_fit)
0x3ee20: msg_main_thread(void*) + 0x10 (ccl_msg)
0x5abc: thr_final_wrapper + 0xc (ccl_thr)
0x3eedf: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
0x9f8c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
0x8b29: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x5aff: thr_thread_wrapper + 0x15 (ccl_thr)
0x40e91: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb2 (ccl_msg)
0x237fd: __libc_start_main + 0xcd (c.so.6)
End-trace
Executable: quartus
Comment:
I changed the PCI PERST# pin to 1.8V to be compatable with the BGA NVMe I'm using and Quartus crashed. That is the only thing I changed.
System Information
Platform: linux64
OS name: This is
OS version:
Quartus Prime Information
Address bits: 64
Version: 20.1.1
Build: 720
Edition: Standard Edition
Hi BrianM,
Below is a similar case.
https://www.intel.com/content/www/us/en/support/programmable/articles/000080960.html
Probably the error is due to incorrect voltage set for the pin in .qsf (quartus settings file).
Sheng
- ShengN_altera
Hi BrianM,
Sheng- BrianM
FYI: for anyone else who finds this thread in the future. On the Cyclone V, the PERST# pin is 3.3V only and Quartus will crash (bug!) as shown above if it isn't set to 3.3V. The software should not allow you to change it.
To use a 1.8V only BGA NVMe (ie Swissbit) you need to add a reverse biased schottky diode in series with the signal to the NVMe so the an FPGA low will pull the signal low, but a high will simply let the signal go to whatever pullup is on the BGA package.I think Swissbit dropped the ball on this, since 3.3V is the PCIe specification for the signal.
- ShengN_altera
Hi BrianM,
Appreciate your helpful information on this thread. It really matter to community. I’m also glad that your question has been resolved.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Sheng
