Changed PERST# to 1.8V and Quartus crashed.
- 4 years ago
Hi BrianM,
Below is a similar case.
https://www.intel.com/content/www/us/en/support/programmable/articles/000080960.html
Probably the error is due to incorrect voltage set for the pin in .qsf (quartus settings file).
Sheng
Hi BrianM,
Sheng
- BrianM4 years ago
FYI: for anyone else who finds this thread in the future. On the Cyclone V, the PERST# pin is 3.3V only and Quartus will crash (bug!) as shown above if it isn't set to 3.3V. The software should not allow you to change it.
To use a 1.8V only BGA NVMe (ie Swissbit) you need to add a reverse biased schottky diode in series with the signal to the NVMe so the an FPGA low will pull the signal low, but a high will simply let the signal go to whatever pullup is on the BGA package.I think Swissbit dropped the ball on this, since 3.3V is the PCIe specification for the signal.
- ShengN_altera4 years ago
Hi BrianM,
Appreciate your helpful information on this thread. It really matter to community. I’m also glad that your question has been resolved.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Sheng
