Changed PERST# to 1.8V and Quartus crashed.
- 4 years ago
Hi BrianM,
Below is a similar case.
https://www.intel.com/content/www/us/en/support/programmable/articles/000080960.html
Probably the error is due to incorrect voltage set for the pin in .qsf (quartus settings file).
Sheng
Hi BrianM,
Sheng
FYI: for anyone else who finds this thread in the future. On the Cyclone V, the PERST# pin is 3.3V only and Quartus will crash (bug!) as shown above if it isn't set to 3.3V. The software should not allow you to change it.
To use a 1.8V only BGA NVMe (ie Swissbit) you need to add a reverse biased schottky diode in series with the signal to the NVMe so the an FPGA low will pull the signal low, but a high will simply let the signal go to whatever pullup is on the BGA package.
I think Swissbit dropped the ball on this, since 3.3V is the PCIe specification for the signal.
- ShengN_altera4 years ago
Hi BrianM,
Appreciate your helpful information on this thread. It really matter to community. I’m also glad that your question has been resolved.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Sheng
