16 years ago
change the clock cyle from the custom instruction
Windows XP
Quartus: 9.0 32 Bit
SOPC Builder 9.0
Prozessor: EP1S10F780C6
I want to change the Clock-Cycle to multi-cycle for my custom instruction, but i can't change it on the SOPC Builder in the Processor custom instruction Tab.
I use the User Guide:
http://www.altera.com/literature/ug/ug_nios2_custom_instruction.pdf
on the page 29 is the information:
"The Clock Cycles field indicates the type of custom instruction:
combinational logic, multi-cycle, extended, internal register file,
or external interface. If the custom instruction is a fixed length,
multi-cycle custom instruction, you must edit this field to
specify the number of clocks. You must determine this number
based on knowledge of the custom instruction state machine. In
the case of a variable length multi-cycle custom instruction, the
Clock Cycles field displays Variable."
but I can not change the clock-cycle
in the setup interface for the custom instruction, on the Tab Interfaces I have the option Clock-Cycle to 15.
please help me
thanks
1 Reply
    Have you found any solution to this? I have the same problem.
    Thanks in advance.
    --- Quote Start ---
    Windows XP
    Quartus: 9.0 32 Bit
    SOPC Builder 9.0
    please help me
    thanks
    --- Quote End ---
