CDC Interconnect in Platform Designer
It should. Where are you seeing that no clock crossing logic is being added? Have you generated the system and gotten an error or warning?
Hi, I connected the 100MHz clock source to the HPS bridge interfaces.
Then, I connected the 100 MHz clock and its sync reset to the slave interface of the AVMM clock crossing bridge intel IP and the DSP clock to the master interface (https://docs.altera.com/r/docs/683609/25.1.1/quartus-prime-pro-edition-user-guide-platform-designer/avalon-memory-mapped-clock-crossing-bridge-intel-fpga-ip).
Finally, I connect the master interface of the AVMM CDC IP to the slave interface of the AXI bridge Intel FPGA IP and export the master to the top level.
Is this a legal PD design?
- RichardT_altera7 months ago
Looks legal. As long as Platform Designer shows no warnings and the clock/reset domains are handled correctly, this should be a valid design.
Richard Tan- RichardT_altera7 months ago
Let me know if further assistance is required.
Richard Tan- YZhou987 months ago
Thanks, it looks good for now.
