CDC Interconnect in Platform Designer
It should. Where are you seeing that no clock crossing logic is being added? Have you generated the system and gotten an error or warning?
- YZhou987 months ago
Hi, I connected the 100MHz clock source to the HPS bridge interfaces.
Then, I connected the 100 MHz clock and its sync reset to the slave interface of the AVMM clock crossing bridge intel IP and the DSP clock to the master interface (https://docs.altera.com/r/docs/683609/25.1.1/quartus-prime-pro-edition-user-guide-platform-designer/avalon-memory-mapped-clock-crossing-bridge-intel-fpga-ip).
Finally, I connect the master interface of the AVMM CDC IP to the slave interface of the AXI bridge Intel FPGA IP and export the master to the top level.
Is this a legal PD design?
- RichardT_altera7 months ago
Looks legal. As long as Platform Designer shows no warnings and the clock/reset domains are handled correctly, this should be a valid design.
Richard Tan- RichardT_altera7 months ago
Let me know if further assistance is required.
Richard Tan
