CDC-50001 - 1-Bit Asynchronous Transfer Not Synchronized
Hi Or,
The problem found is not enough synchronizer. You may increase the synchronizer by using Parameterizable Macro (ipm_cdc_1clk_sync) check this link https://www.intel.com/content/www/us/en/docs/programmable/772350/24-2/synchronizer-using-single-clock-parameterizable-23701.html
Code changes screenshot:
Tech map viewer screenshot:
Then the CDC-50001 warnings are disappeared.
Based on the future version 24.3 CDC-50001 description (screenshot below), Protect single-bit asynchronous data transfers by a synchronizer chain. Use the CDC parameterizable macros: Single Clock Parameterizable Macro (ipm_cdc_1clk_sync) or Two Clocks Parameterizable Macro (ipm_cdc_2clks_sync). ...To do this, ensure that the destination of an asynchronous transfer forms a chain of two or more registers,
