OrF
2 years agoCDC-50001 - 1-Bit Asynchronous Transfer Not Synchronized
I'm trying to re-open this ticket - I didn't found how , but anyway I tried to change the default Quartus SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 2 (instead of 3) and still get the same warning , ...
OrF
2 years agoI will check the “set_instance_assignment (Synchronization Identification) directly to those remaining registers” as suggested. However, it seems from your response that we might be overlooking the issue. As I mentioned, there are synchronizers in place, so the software should detect them as such, given that there is no logic between the registers. This raises a concern about a potential bug or design flaw. If the constraints you suggest are merely to clean up the report, I am not particularly concerned about that. My primary goal is to understand whether there is actual synchronization or if the tool is detecting an unsynchronized path.
