OrF
2 years agoCDC-50001 - 1-Bit Asynchronous Transfer Not Synchronized
I'm trying to re-open this ticket - I didn't found how , but anyway I tried to change the default Quartus SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 2 (instead of 3) and still get the same warning , ...
ShengN_altera
2 years agoHi,
'Forced if Asynchronous' - the Timing Analyzer identifies synchronization register chains if the software detects an asynchronous signal transfer, even if there is combinational logic or only one register in the chain
Can you try set_instance_assignment (Synchronization Identification) directly to those remaining registers?
Sheng
