OrF
2 years agoCDC-50001 - 1-Bit Asynchronous Transfer Not Synchronized
the Quartus STA reports "CDC-50001 - 1-Bit Asynchronous Transfer Not Synchronized" sync-fifo in my design . at this document "AN 919: Improving Quality of Results with Design Assistant" :https://...
OrF
2 years agoI think it is 3 ? / is it the right option ? and auto ?
sstrell
2 years agoSince it's set to 3 and you only have 2 registers in the destination clock domain, it's not getting recognized as a synch chain. Add an extra register or reduce the chain length, though I'd recommend adding a register because it is much more common to have 2 registers in a row throughout your design so there would be a better chance of chains getting mis-identified.
