9 years agoCan't Simulate Buffer port in ModelSim
Hello everyone, I have the following simple VHDL code for clock frequency division:
---------------------- Frequency division using Variables ------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_divider IS PORT ( clk : IN STD_LOGIC; out2 : BUFFER STD_LOGIC); END freq_divider; ----------------------------------------- ARCHITECTURE example OF freq_divider IS BEGIN PROCESS (clk) VARIABLE count2 : INTEGER RANGE 0 TO 7; BEGIN IF (clk'EVENT AND clk='0') THEN count2 := count2 + 1; IF (count2 = 3) THEN out2 <= NOT out2; count2 := 0; END IF; END IF; END PROCESS; END example; ----------------------------------------- But when I try to Simulate it with modelsim-altera the (out2) signal does not give me any value. I was wondering is it because the port is assigned as (buffer)????? Please help me. Thanks2 Replies
Did you provide a clock on the clock port?
with "does not give any value" I assume you mean 'U'? If so, it's because you never initialize "out2" to any value. Also, I agree with Tricky, you need a testbench that provides a clock. If you don't know about testbenches, Google has plenty of examples, e.g. here: https://www.doulos.com/knowhow/vhdl_designers_guide/test_benches_part_1/ (https://www.doulos.com/knowhow/vhdl_designers_guide/test_benches_part_1/). Best regards, GooGooCluster
