16 years agoI can´t find the signal LSD_SEG in the code you posted.
But one of the rules of VHDL is that you cannot assign a signal in more than one place. This error is a result of you assigning a value to the specified signal in more than one place. Check that you are not assigning this signal outside of a process and inside, or in two or more different processes or in two or more different places outside of a process. Right clicking on the warning in Quartus and clicking help, should help you to understand why you get this error.
