18 years agoWell now it seems like nothing is happening. Shifting right shifts the wrong amounts and shifting left doesn't work at all.
Can anyone spot anything glaring?ENTITY ShiftRegister IS
PORT (aluIn : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
shift : IN STD_LOGIC_VECTOR(2 DOWNTO 0);--rotate amount
shiftRight : IN STD_LOGIC;--if 1, right, if 0, left
aluOut : OUT STD_LOGIC_VECTOR(15 DOWNTO 0)--rotated output
END ShiftRegister;
ARCHITECTURE Structure OF ShiftRegister IS
SIGNAL alu1: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL alu2: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL alu3: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL tempL1: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL tempR1: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL tempL2: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL tempR2: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL tempL3: STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL tempR3: STD_LOGIC_VECTOR(15 DOWNTO 0);
COMPONENT busmux4to1
PORT
selectIn: IN STD_LOGIC_VECTOR(1 DOWNTO 0);
a: IN STD_LOGIC_VECTOR(15 DOWNTO 0);
b: IN STD_LOGIC_VECTOR(15 DOWNTO 0);
c: IN STD_LOGIC_VECTOR(15 DOWNTO 0);
d: IN STD_LOGIC_VECTOR(15 DOWNTO 0);
e: OUT STD_LOGIC_VECTOR(15 DOWNTO 0)
END COMPONENT;
BEGIN
--4 rotation
tempL1<=aluIn(11 DOWNTO 0) & aluIn(15 DOWNTO 12);
tempR1<=aluIn(3 DOWNTO 0) & aluIn(15 DOWNTO 4);
stage0: busmux4to1 PORT MAP(shiftRight & shift(2),aluIn,tempL1,aluIn,tempR1,alu1);
--2 rotation
tempL2<=alu1(13 DOWNTO 0) & alu1(15 DOWNTO 14);
tempR2<=alu1(1 DOWNTO 0) & alu1(15 DOWNTO 2);
stage1: busmux4to1 PORT MAP(shiftRight & shift(1),alu1,tempL2,alu1,tempR2,alu2);
--1 rotation
tempL3<=alu2(14 DOWNTO 0) & alu2(15);
tempR3<=alu2(0) & alu2(15 DOWNTO 1);
stage2: busmux4to1 PORT MAP(shiftRight & shift(0),alu2,tempL3,alu2,tempR3,alu3);
aluOut<=alu3;
END Structure;
