18 years agoHello,
in the shown code, not only alu, but also tempL and tempR have multiple drivers. In concurrent code part, you are not allowed to make multiple assignment to a signal. I assume, you are intending a process, but it must coded as such. Furthermore, you can't use the multiplexer component in a process, but you could use a similar function instead. For temporary results, you must variables with variable assignment operator ":=". It would be allowed to make multiple assignments to a signal as in the example, but not with the intended effect of creating an intermediate result. Regards, Frank
