8 years agoCan't perform simulation of IP file because no simulation model files were detected
I am facing this error "Error: Error: Can't perform simulation of IP file /home/phung/Documents/riffa/fpga/altera/de4/DE4Gen2x8If128/ip/PCIeGen2x8If128_core.v because no simulation model files were detected". However, from the screenshot below, I have included pciegen2x8if128_core.vo IP functional simulation model file as described in https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-5v3.pdf#page=16
(https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-5v3.pdf#page=16) What else had I missed ? https://alteraforum.com/forum/attachment.php?attachmentid=14911&stc=12 Replies
Your screenshot is too small to see anything. What exactly are you executing when you see the error?
It seems like altera forum limits and crops my file size (therefore photo size) to save server disc space.
I have uploaded the screenshot to https://i.imgur.com/mharvjq.png Just to say that I have included PCIeGen2x8If128_core.vo IP functional simulation model file, yet I am still getting the following error: --- Quote Start --- Error: Error: Can't perform simulation of IP file /home/phung/Documents/fpga_overlay/riffa/fpga/altera/de4/DE4Gen2x8If128/ip/PCIeGen2x8If128_core.v because no simulation model files were detected Error: Error: You did not generate the simulation model files or you generated the IP file using an older version of Intel FPGA IP which is not supported by RTL NativeLink Simulation Error: Error: Regenerate the IP and simulation model files using the latest version of Intel FPGA IP for RTL NativeLink Simulation flow to function correctly Error: Error: NativeLink simulation flow was NOT successful --- Quote End ---
