Can't open .qbf file due to no device support installed, but Cyclone IV support is installed. Quartus Prime 19.1 Lite.
- 6 years ago
Something is messed up with the installation. I'd delete Quartus and then reinstall the devices. Do the device installation before doing any additional patches. And it looks like the patch you mention is for Standard edition (std) so that may have something to do with it as well.
#iwork4intel
So you're saying that every time you open Quartus, you get the message about missing device support or is it only when you try to open this co-worker's project?
Can you just open Quartus and create a new project with the New Project Wizard on the File menu and select a Cyclone IV as the target device?
#iwork4intel
Every time I open Quartus, I get the message about missing device support.
I can dismiss the message. But if I try to create a new Quartus Prime Project using the New Project Wizard (or manually with File, New..., New Quartus Prime Project), I get the same missing device support message.
