PGötz
6 years agoCan't locate Getopt/Long.pm when generating a Qsys Project
Quartus 19.1 has issues with its perl distribution on Linux. When generating a Qsys project, I get the following error: ``` Can't locate Getopt/Long.pm in @INC (you may need to install the Getopt::...
SSchu40
6 years agoFor me inserting the line
export PERL5LIB=/opt/intel_fpga/quartus/linux64/perl/lib/5.28.1
into
~/.bashrc
solved the problem. Please note that the application must be restarted to inherit the environment variable.
PGötz
6 years agoYeah, but this wasn't necessary with previous versions of Quartus and it could cause further problems or compatibility issues with my systems perl installation.
I have already another "fix" in use (as mentioned above), but would prefer if Intel would recognize this bug and fix it in the next build/release
