12 years agoCan't launch the Modelsim-Altera Software
My OS is Windows 8 64 bit. I'm using Quartus II 13.1 Web Edition, and Modelsim 10.1d. My path in EDA Tools is set to "C:\altera\13.1\modelsim_ase\win32aloem", when I go Tools > Run Similation Tool > RTL Simulation; I get this Nativelink Error: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path... I can manually start it by the way. Thank you Baris Yakut31 Replies
--- Quote Start --- when you add the path: "C:\altera\13.1\modelsim_ase\win32aloem" you need to add "\" --- Quote End --- This also worked for me, using Quartus II 13.1 Update 4 newly installed on Windows 7 64-bit. Thanks! - Altera_Forum
+1 on this- Tried it and it works
Thanks, it works!
This should be reported as a bug.
OH;
I hade the same proplem and I add "\" and it was fixed. Thanks; - Altera_Forum
--- Quote Start --- It works!!!!!! when you add the path: "C:\altera\13.1\modelsim_ase\win32aloem" you need to add "\" result: "C:\altera\13.1\modelsim_ase\win32aloem\" and it works!!!! --- Quote End --- I had this same problem and this solution worked!!! Thanks a lot!! - Altera_Forum
OK, this is a link to the licensed Modelsim-Altera. But what's the path to the ModelSim starter Edition?
--- Quote Start --- OK, this is a link to the licensed Modelsim-Altera. But what's the path to the ModelSim starter Edition? --- Quote End --- "modelsim_ase" is Model Sim Altera Starter Edition. "C:\altera\13.1\modelsim_ase\win32aloem\" is the correctly location for the Starter Edition. (and another +1 like to taquionbcn for posting the solution) - Altera_Forum
Thanks!!!!
thanks, it works!!
