10 years agoCan't launch Blueprint Platform Designer from Quartus Prime Pro Edition...
Actually I have discovered that Blueprint Platform Designer "is" actually starting up as I see it appear in the Processes tab of Task Manager when I launch it from Quartus. The problem is that it never opens a Window for me to work in....
Is this a known issue or do you know of something that I may not have set correctly? thanks, david3 Replies
Same thing is happening to me. Quartus Prime Pro 15.1.1 running on Windows 7 64-bit SP1. Why no response to David's post?
You have to close the Quartus window whenever you want to use the Blueprint Platform Designer
That's not true, jaycn. In my case it was a licensing issue. If you try to run Blueprint without a license you get the behavior descibed above.
