10 years agoCan't launch Blueprint Platform Designer from Quartus Prime Pro Edition...
Actually I have discovered that Blueprint Platform Designer "is" actually starting up as I see it appear in the Processes tab of Task Manager when I launch it from Quartus. The problem is that it ne...
10 years agoThat's not true, jaycn. In my case it was a licensing issue. If you try to run Blueprint without a license you get the behavior descibed above.
