9 years agoCan't instantiate Signal Tap using megafunction tool in Quartus 17.0.1
I am attempting to instantiate a signal tap core using the megafunction flow. Quartus generates the IP but when I instantiate it in my project and compile I get the following error. Error(1378...
8 years agoHere is my code. I don't think it has anything to do with the instantiation because if I generate the IP as a Verilog module things work. Why do I get this error generating the IP core in VHDL?
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity adder_top is port( clock : in std_logic; resetn : in std_logic; oready : out std_logic; ivalid : in std_logic; idata : in std_logic_vector(31 downto 0); ovalid : out std_logic; iready : in std_logic; odout : out std_logic_vector(31 downto 0) ); end adder_top; architecture Behavioral of adder_top is component signal_tap is port ( acq_clk : in std_logic := 'X'; -- clk acq_data_in : in std_logic_vector(63 downto 0) := (others => 'X'); -- acq_data_in acq_trigger_in : in std_logic_vector(0 downto 0) := (others => 'X') -- acq_trigger_in ); end component signal_tap; signal s_sum : unsigned(32 downto 0); signal s_trigger : std_logic_vector(0 downto 0); begin ovalid <= '1'; odout <= std_logic_vector(s_sum(31 downto 0)); oready <= '1'; s_trigger(0) <= ivalid; process(clock) begin if rising_edge(clock) then if (resetn='0') then s_sum <= (others=>'0'); else s_sum <= s_sum + X"00000001"; end if; end if; end process; signal_tap_inst : component signal_tap port map ( acq_clk => clock, acq_data_in => idata(31 downto 0) & std_logic_vector(s_sum(31 downto 0)), acq_trigger_in => s_trigger ); end Behavioral;
