14 years ago
Can't inplement this code...Help!
I need to inplement this code and than use it for another code:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
package ad_filt is
constant NUM_TAPS : integer := 16:
constant mu : integer := 16;
type sh_reg is array (0 to NUM_TAPS-1) of std_logic_vector(15 downto 0);
type tmp_reg is array (0 to NUM_TAPS-1) of std_logic_vector(31 downto 0);
end ad_filt;
Then I use command in another code:
use work.ad_filt.ALL;
How to inplement this code and use it for another code?
    whats the problem? Have you forgotten to add the VHD file this package is in to the project?
    --- Quote Start ---
    library IEEE;
    package ad_filt is
    end ad_filt;
    I need to implement this code above.And after that to use it in another code with command:
    When I try to inplement code above I have lots of errors...My English is bad so I have difficulty to explain.
    There is nothing wrong with the code you posted. I can only guess the error is elsewhere.
    Thanks Tricky...
    Is there some tutorial where I can see how to 2,3,4 or more VHDL codes put in one quartus project?
    Tomorrow I will put errors here,then you can see whats wrong...Thanks anyway!
