15 years agoAndre.krueger (above) has the correct answer.
You need the 64 bit jtagserver on a 64 bit kernel as the kernel 32/64 bit conversions sometimes have problems - the 32 bit jtagserver is unreliable on a 64 bit kernel. Installing the 11.0 programmer install after the 11.0 web edition should get the correct files installed.
