15 years agoI had the same problem after installing q11.0. I tried different things but there was no usb blaster available. After this i installed q10.1 without uninstalling q11.0 and now the usb blaster was selectable in both versions of quartus. Then i uninstalled q10.1 and then there was no blaster selectable again.
I solved the problem by installing the stand alone programmer (v11) after installing q11.0.
