17 years ago
Can't generate .vo file
My design includes a fir filter generated using fir_compiler 3.3.1.
I want to generate the .vo file of this design and do function simulation in modelsim.
When doing the complete compilation, analysis & synthesis, fitter ,assembler and classic timing analysis are all OK. But the EDA Netlist Writer fails and can't generate this .vo file . The error is " Can't generate netlist output files because the file "C:/altera/megacore/fir_compiler-v3.3.1/lib/tdl_da_lc.v" is an OpenCore Plus time-limited file".
How to solve it ?
Thanks!
Tigre
    If this IP doesn't support try-before-you-buy simulation, then you have to pay for a license. You can use the OpenCore .sof file to try out the IP in hardware without a license.
    who knows the meaning of these equations which has been written in .vo file?
    please help me. I have no idea about LCELL and CARRY!
    \Mult0|auto_generated|le3a [0] = LCELL(\Mult0|auto_generated|cs1a [0] $ (\A~combout [7] & \Mult0|auto_generated|cs2a [0]))
    \comp1|LessThan0~47COUT1_98 = CARRY(\A~combout [1] & \B~combout [1] & !\comp1|LessThan0~52COUT1_96 # !\A~combout [1] & (\B~combout [1]# !\comp1|LessThan0~52COUT1_96 ))
    The said LCELL and CARRY are the real gate-level entities used in Altera FPGAs. You can read a functional description in the designing with low-level primitives user guide http://www.altera.com/literature/ug/ug_low_level.pdf. The logic expressions are generic ABEL, their meaning is obvious to my opinion, cause ony NOT, AND, OR and XOR are used from of the ABEL operators.
    Dear Fvm!,
    Thanks for your very useful help. I have another question :)
    Is there any way to extract the gate-level netlist of synthesized behavioral verilog code in Quartus or Xilinx ISE?
    Thank U so much.
