12 years ago
Can't fit design in device after upgrade from 13.0SP1 to 13.1
I have a project for the MAX V "5M240ZM100C5" CPLD, almost at the max capacity of the device.
Previously I was using 32bit PC, Windows 7 and Quartus II 13.0 SP1 Web Edition, and was able to successfully compile and fit the design on the device.
Here is a piece of the log from the Fitter:
Info: Running Quartus II 32-bit Fitter    Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
Info: Command: quartus_fit --read_settings_files=off --write_settings_files=off InterfaceLogic -c InterfaceLogic
Info: qfit2_default_script.tcl version:# 1
Info (171003): Fitter is performing an Auto Fit compilation, which may decrease Fitter effort to reduce compilation time
Info (332144): No user constrained base clocks found in the design
Info (332128): Timing requirements not specified -- optimizing circuit to achieve the following default global requirements
    Info (332127): Assuming a default timing requirement
Info (332111): Found 5 clocks
Info (186079): Completed User Assigned Global Signals Promotion Operation
Info (186079): Completed Auto Global Promotion Operation
Info (176234): Starting register packing
Info (186391): Fitter is using Normal packing mode for logic elements with Auto setting for Auto Packed Registers logic option
Info (186468): Started processing fast register assignments
Info (186469): Finished processing fast register assignments
Info (176235): Finished register packing
Info (171121): Fitter preparation operations ending: elapsed time is 00:00:01
Info (170189): Fitter placement preparation operations beginning
Info (170190): Fitter placement preparation operations ending: elapsed time is 00:00:00
Info (11888): Total time spent on timing analysis during the Fitter is 0.02 seconds.
Info (170216): Fitter cannot place all nodes on current device -- Fitter will automatically make another fitting attempt and tightly pack logic elements
Info (186391): Fitter is using Minimize Area packing mode for logic elements with Auto setting for Auto Packed Registers logic option
Info (171121): Fitter preparation operations ending: elapsed time is 00:00:00
Info (186391): Fitter is using Minimize Area with Chains packing mode for logic elements with Auto setting for Auto Packed Registers logic option
Info (170191): Fitter placement operations beginning
Info (170137): Fitter placement was successful
Info (170192): Fitter placement operations ending: elapsed time is 00:00:01
Info (170193): Fitter routing operations beginning
Info (170195): Router estimated average interconnect usage is 28% of the available device resources
    Info (170196): Router estimated peak interconnect usage is 28% of the available device resources in the region that extends from location X0_Y0 to location X8_Y5
Info (170194): Fitter routing operations ending: elapsed time is 00:00:01
Info (170202): The Fitter performed an Auto Fit compilation.  No optimizations were skipped because the design's timing and routability requirements required full optimization.
Info (11888): Total time spent on timing analysis during the Fitter is 0.55 seconds.
Info (11218): Fitter post-fit operations ending: elapsed time is 00:00:00
Info: Quartus II 32-bit Fitter was successful. 0 errors, 3 warnings
On the report I have a total of logic elements of 150 / 160 ( 94 % ).
Now I bought a new PC i7 64bit, Windows 8.1 64bit and installed the Quartus II 13.1 Web Edition.
And now the compilation fails at the Fitter, for the log it seems that no optimization is atempted:
Info: Running Quartus II 64-Bit Fitter
    Info: Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
Error (170011): Design contains 178 blocks of type logic cell.  However, the device contains only 160 blocks.
So I did some testing to find out if I can manage to solve this issue, I checked the settings and it seemed to be identical on both setups.
Running the 32bit of 13.1 also got the same issue.
Then I tried downloading the version 13.0 SP1 Web Edition again for the new PC, and successfully fitted the design.
Did this happened to someone?
Is this situation normal, due to new license limitations or something, or do I need to change any settings in the software?
Thank you
