16 years ago --- Quote Start --- Hi,pletz, Glad to receive your reply.What I said is within the FPGA,no driving source,except the power supply device.What I mean is that we should define the minimal value,not the max one,cause that the setuptime is a margin that the much the better.So the slack should be actual - required. regards --- Quote End --- Hi, tsu and tco settings define the requirements for the inputs and outputs of the FPGA. They are not used for the internal timing. The internal setup and hold requirements are handled by Quartus itself by defining the required clock speed. Kind regards GPK
