9 years agoCannot simulate TSE - Design unit not found
I am trying to simulate my module from sopc using the triple speed ethernet ip.when I try to simulate I get the error "altera_tse_mac.v(376): Instantiation of 'altera_tse_top_gen_host' failed. The design unit was not found.# Region: /macb/b2v_inst/the_triple_speed_ethernet_0/altera_tse_mac_inst " So i grabbed altera_tse_top_gen_host.v from the library and added to working directory and tried to compile... then i get this error Error: altera_tse_top_gen_host.v( syntax error, unexpected non-printable character 0x8b Error: altera_tse_top_gen_host.v( syntax error, unexpected $undefined, expecting "class" So I open up the file altera_tse_top_gen_host.v in notepad++ to see why its not reading the model and its....gibberish? Full of weird characters. Is this a fault in the altera library? Or is the v file meant to look like that. Thanks1 Reply
The tse Verilog file will be an encrypted IP core so it will look like gibberish when you open it. You will need a simulation model for it if there is one.
