16 years agothks to thepancake.
I downloaded the quartus 9.1 as you advised. But now I got another problem in the installation. When I run the install scripts in terminal, I got the response --- Quote Start --- If: expression syntax --- Quote End --- My default shell is bash and tcsh is installed. I changed the default shell from bash to csh with command chsh, but it seems like there is no any help and the problem remained.
