Cannot run stimulus module using Quartus Prime?
Attempting to learn Verilog right now. I am currently running through Verilog HDL by Palanatkir and am using Quartus Prime Lite as my current EDA. I am very new at this but just wondering, the book has us code a stimulus block as one of our very first exercises. I cannot figure out how to get Quartus to compile with it, as Quartus just states that the top level block has no logic.
Here is my code:
module stimulus;
reg clk;
reg reset;
wire q;
R_CC rcc0(q, clk, reset);
initial
clk = 1'b0; // set clk to 0
always
# 5 clk = ~clk; // toggle clk every 5 tu
initial
begin
reset = 1'b1;
# 15 reset = 1'b0;
# 180 reset = 1'b1;
# 10 reset = 1'b0;
# 20 $finish; // terminate sim
end
initial
$monitor($time, " Output q = %d", q);
endmodule
// module - basic building block of Verilog
// Ripple Carry Counter
module R_CC(q, clk, reset);
output q; // io signal and vector decl
input clk, reset;
T_FF tff0(q, clk, reset);
T_FF tff1(q, q, reset);
T_FF tff2(q, q, reset);
T_FF tff3(q, q, reset);
endmodule
module T_FF (q, clk, reset);
output q;
input clk, reset;
wire d;
D_FF dff0(q, d, clk, reset);
not nl(d, q); // not is a Verilog primative
endmodule
module D_FF(q, d, clk, reset);
output q;
input d, clk, reset;
reg q; // wtf
always @(posedge reset or negedge clk)
if (reset)
q <= 1'b0;
else
q <= d;
endmodule Maybe I am using the wrong tool? Should I be using ModelSim or something similar?4 Replies
This is a testbench, and intended to be run in a simulator. Quartus is a tool for compiling code for FPGAs, and not a proper simulator (it does have a very basic simulator, but it doesnt understand testbenches properly)
This code needs to be ruin in something like Modelsim - Altera_Forum
Thank you!
RTL that you can implement in the FPGA needs to be "synthesizable" So in the code above things like# and $monitor do not map to hardware resources that are inside the FPGA and are provided in the language for the reasons Tricky said. If you google "synthesizable verilog" you'll find a lot of topics on this to help you identify what parts are synthesizable and which are simulation only. In Quartus there are a bunch of templates you can refer to which should all be synthesizable, with a verilog file open in Quartus go to Edit --> Insert Template and navigate to the verilog templates to see examples of how you code various synthesizable blocks.
Hey I forgot to read this at the time (and I think I missed it) because school had started to ramp up and this brick wall kind of discouraged me but, I just started to get back to studying Verilog on my own.
I actually had the exact same problem and ended up google searching back to my original question and this helped so much. Verilog templates are great examples and explain a lot. Appreciate it so much.
