Altera_ForumHonored Contributor14 years agoCannot import uClinux to Nios II IDE (Eclipse) Hi, i'm trying to import the uClinux-dist to Nios2 IDE (eclipse) like the Altera Wiki says alterawiki.com/wiki/Nios_II_IDE . But I have some troubles in the second step, importing the uClinux dist...Show More
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
