Cannot drive PLL from a altclkctrl block
I am working on a MAX10 10M50 device with Quartus Prime lite 2021.1.0
My design uses an external IO pin as a clock source. This pin is NOT a dedicatd clock pin.
I instantiated a altclkctrl bock to route this pin to the global clock resource. The output of that block is connected to the input of a PLL.
Still I get en error telling me that the PLL cannot be placed because it's input is not connected to a non-inverted input pin, another PLL or a clock control block. Then it states that it is driven by a clock control block:
Warning (15899): PLL "pll:pll_1|altpll:altpll_component|pll_altpll:auto_generated|pll1" has parameters clk0_multiply_by and clk0_divide_by specified but port CLK[0] is not connected
Error (15065): Clock input port inclk[0] of PLL "pll:pll_1|altpll:altpll_component|pll_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Info (15024): Input port INCLK[0] of node "pll:pll_1|altpll:altpll_component|pll_altpll:auto_generated|pll1" is driven by clkctrl:clkctrl_1|clkctrl_altclkctrl_0:altclkctrl_0|clkctrl_altclkctrl_0_sub:clkctrl_altclkctrl_0_sub_component|wire_clkctrl1_outclk which is OUTCLK output port of Clock control block type node clkctrl:clkctrl_1|clkctrl_altclkctrl_0:altclkctrl_0|clkctrl_altclkctrl_0_sub:clkctrl_altclkctrl_0_sub_component|clkctrl1
So what's wrong here? How can I make this work?
- sstrell
Can you show your code and how you've made the connections? The warning about CLK[0] not being connected could be part of the issue.
- Ash_R_Altera
The ALTCLKCTRL block inclk signal has following restriction:
Clock pins, clock outputs from the PLL, and core signals can drive the inclk[] port.
Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_clkpll.pdf#page=51, Table 14
The input clock of the ALTCLKCTRL should be driven by a dedicated clock input pin and not just any IO pin.
- Ash_R_Altera
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
