16 years ago --- Quote Start --- It seems to be getting 3.3v out of thin air for the power supply for the 74HC244 which is meant to be off the board (which wasnt connected) --- Quote End --- Not connecting VCCIO can be actually another reason, why the self elaborated "Byte Blaster" isn't working correctly. In my opinion, a HC244 isn't particularly suited for 5/3.3V level conversion. You should rather use a buffer, that allows to overdrive the inputs above the supply, e.g. VHC244. I've used a respective ByteBlaster replacement for years, see attachment, but I prefer USB Blaster performance.
